Demo Title: Blind Speech Extraction Based on MMSE STSA Estimator and ICA-Based Noise Estimation Authors: - Masanobu Go (e-mail: masanobu-g@is.naist.jp) - Hiroshi Saruwatari (e-mail: sawatari@is.naist.jp) - Takayuki Inoue - Kiyohiro Shikano (Go and Saruwatari are corresponding persons.) Affiliation: - Nara Institute of Science and Technology, JAPAN ---------------------------------------------- Abstract: We propose a new method for robust blind speech extraction under realistic noise environments. We use a combination method of ICA-based noise estimation [1], channel-wise nonlinear denoising processing [2] based on Dynamic minimum mean-square error (MMSE) short-time spectral amplitude (STSA) estimator [3], DOA estimator by Minimum Variance method, and (4) Delay-and-Sum (DS) beamformer steered to the estimated DOA. First, Infomax-type ICA-based noise estimator can cancel out the target point-source speech and extract the noise estimate with high accuracy. Next, we apply channel-wise denoising processing [2] to the observed signals based on the estimated noise, in which we use a Dynamic MMSE STSA estimator [3] with momentarily estimated instantaneous a posteriori SNR. Finally, based on the DOA estimated from the channel-wise outputs, we summarize the channel-wise MMSE STSA estimator outputs via DS. Such a "channel-wise nonlinear processing with post-DS" structure leads to less musical noise [2]. References: [1] Y. Takahashi, T. Takatani, K. Osako, H. Saruwatari, and K. Shikano, ``Blind spatial subtraction array for speech enhancement in noisy environment,'' IEEE Transactions on Audio, Speech and Language Processing, vol.17, no.4, pp.650--664, 2009. [2] Y. Takahashi, Y. Uemura, H. Saruwatari, K. Shikano, K. Kondo, ``Musical noise analysis based on higher order statistics for microphone array and nonlinear signal processing," Proc. IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP2009), pp.229--232, 2009. [3] R. Okamoto, Y. Takahashi, H. Saruwatari, K. Shikano, ``MMSE STSA estimator with nonstationary noise estimation based on ICA for high-quality speech enhancement," Proc. ICASSP 2010, pp.4778--4781, 2010.
