Demo Title: Application of Generalized Spectral Subtraction to Blind Speech Extraction with ICA-Based Noise Estimation Authors: - Nobuhisa Hirata (e-mail: nobuhisa-h@is.naist.jp) - Hiroshi Saruwatari (e-mail: sawatari@is.naist.jp) - Takayuki Inoue - Kiyohiro Shikano (Hirata and Saruwatari are corresponding persons.) Affiliation: - Nara Institute of Science and Technology, JAPAN ---------------------------------------------- Abstract: We newly apply a generalized spectral subtraction to robust blind speech extraction under realistic noise environments. First, Infomax-type ICA-based noise estimator can cancel out the target point-source speech and extract the noise estimate with high accuracy [1]. Next, we apply channel-wise denoising processing to the observed signals based on the estimated noise, in which we introduce "Generalized Spectral Subtraction (GSS) [2]" with the subtraction domain exponent of 0.001; such a compressed-domain subtraction leads to less musical noise. DOA is estimated via the outputs of channel-wise GSS based on minimum variance DOA estimator. Finally, based on the estimated DOA, we summarize the channel-wise GSS outputs via DS. Such a "channel-wise SS with post-DS" structure leads to less musical noise [3]. References: [1] Y. Takahashi, T. Takatani, K. Osako, H. Saruwatari, and K. Shikano, ``Blind spatial subtraction array for speech enhancement in noisy environment,'' IEEE Transactions on Audio, Speech and Language Processing, vol.17, no.4, pp.650--664, 2009. [2] T. Inoue, Y. Takahashi, H. Saruwatari, K. Shikano, K. Kondo, "Theoretical Analysis of Musical Noise in Generalized Spectral Subtraction: Why Should not Use Power/Amplitude Subtraction?," Proc. EUSIPCO2010 (in printing). [3] Y. Takahashi, Y. Uemura, H. Saruwatari, K. Shikano, K. Kondo, ``Musical noise analysis based on higher order statistics for microphone array and nonlinear signal processing," Proc. IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP2009), pp.229--232, 2009.
