POSTER SESSION 2
Tuesday 28, 13:40 - 15:20
Chair: Tülay Adali
| ID paper | Title and authors |
Theory | |
| 8 | ICA separability of nonlinear models with references: general properties and application to Heisenberg-coupled quantum states (qubits) |
| Yannick Deville | |
| 10 | Adaptive underdetermined ICA for handling an unknow number of sources |
| Andreas Sandmair, Alam Zaib and Fernando Puente León | |
| 17 | Independent Phase Analysis: Separating Phase-Locked Subspaces |
| Miguel Almeida, José Bioucas-Dias and Ricardo Vigario | |
| 18 | Second and Higher-Order Correlation Analysis of Multiple Multidimensional Variables by Joint Diagonalization |
| Xilin Li, Matthew Anderson and Tulay Adali | |
| 19 | Independent Component Analysis of Time/Position Varying Mixtures |
| Michael Shamis and Yehoshua Zeevi | |
| 21 | Random Pruning of Blockwise Stationary Mixtures for Online BSS |
| Alessandro Adamo and Giuliano Grossi | |
| 26 | Use of prior Knowledge in a non-Gaussian method for learning linear structural equation models |
| Takanori Inazumi, Shohei Shimizu and Takashi Washio | |
| 27 | A new performance index for ICA: properties, computation and asymptotic analysis |
| Pauliina Ilmonen, Klaus Nordhausen, Hannu Oja and Esa Ollila | |
| 29 | Blind operation of a reccurent neural network for linear-quadratic source separation: fixed points, stabilization and adaptation scheme |
| Yannick Deville and Shahram Hosseini | |
| 39 | Statistical Model of Speech Signals Based on Composite Autoregressive System with Application to Blind Source Separation |
| Hirokazu Kameoka, Takuya Yoshioka, Mariko Hamamura, Jonathan Le Roux and Kunio Kashino | |
| 50 | Information-theoretic Model Selection for Independent Components |
| Claudia Plant, Fabian Theis, Anke Meyer-Baese and Christian Böhm | |
| 53 | Blind Source Separation of Overdetermined Linear-quadratic Mixtures |
| Leonardo Duarte, Ricardo Suyama, Romis Attux, Yannick Deville, Joao Romano and Christian Jutten | |
| 54 | Constrained Complex-Valued ICA Without Permutation Ambiguity Based on Negentropy Maximization |
| Qiu-Hua Lin, Li-Dan Wang, Jian-Gang Lin and Xiao-Feng Gong | |
| 63 | Times Series Causality Inference using Echo State Networks |
| N. Michael Mayer, Oliver Obst and Chang Yu-Chen | |
| 73 | Complex Blind Source Separation via Simultaneous Strong Uncorrelating Transform |
| Hao Shen and Martin Kleinsteuber | |
| 79 | A General Approach for Robustification of ICA Algorithms |
| 104 | Strong Sub-and Super-Gaussianity |
| Jason Palmer, Ken Kreutz-Delgado and Scott Makeig | |
| Telecom | |
| 6 | Hybrid Channel Estimation Strategy for MIMO systems with Decision Feedback Equalizer |
| Héctor José Pérez Iglesias, Adriana Dapena, Paula Castro and José A. García-Naya | |
| 34 | An Alternating Minimization Method for Sparse Channel Estimation |
| Rad Niazadeh, Massoud Babaie-Zadeh and Christian Jutten | |
| 87 | A Method for Filter Equalization in Convolutive Blind Source Separation |
| Radoslaw Mazur and Alfred Mertins | |
| 88 | Cancellation of nonlinear Inter-Carrier Interference in OFDM Systems with Nonlinear Power-Amplifiers |
| Alexandre Fernandes, Joao Cesar Mota and Gérard Favier |
