POSTER SESSION 3
Wednesday 29, 13:40 - 15:20
Chair: Lieven De Lathauwer
| ID paper | Title and authors |
Biomedical applications & Sparsity | |
| 9 | Fast Block-Sparse Decomposition Based on SLO |
| Sina Hamidi Ghalehjegh, Massoud Babaie-Zaded and Christian Jutten | |
| 61 | Second-order source separation based on prior knowledge realized in a graph model |
| Florian Blöchl, Andreas Kowarsch and Fabian Theis | |
| 65 | Noise adjusted PCA for finding the subspace of evoked dependent signals from MEG data |
| Florian Kohl, Gerd Wübbeler, Dorothea Kolossa, Clemens Elster, Markus Bär and Reinhold Orglmeister | |
| 74 | Binary Sparse Coding |
| Marc Henniges, Gervasio Puertas, Jörg Bornschein, Julian Eggert and Jörg Lücke | |
| 89 | A Multichannel Spatial Compressed Sensing Approach for Direction of Arrival Estimation |
| Aris Gretsistas and Mark D. Plumbley | |
| 96 | Robust second-order source separation identifies experimental responses in biomedical imaging |
| Fabian Theis, Nikola Müller, Claudia Plant and Christian Böhm | |
| 108 | Decomposition of EEG signals for multichannel neural activity analysis in animal experiments |
| Vincent Vigneron, Hsin Chen, Yen-Tai Chen, Hsin-Yi Lai and You-Yin Chen | |
Nonnegativity & Images | |
| 3 | Using Non-Negative Matrix Factorization for Removing Show-Through |
| Farnood Merrikh-Bayat, Massoud Babaie-Zadeh and Christian Jutten | |
| 5 | Nonlinear Band Expansion and 3D Nonnegative Tensor Factorization for Blind Decomposition of Magnetic Resonance Image of the Brain |
| Ivica Kopriva and Andrzej Cichocki | |
| 28 | Informed source separation using latent components |
| Antoine Liutkus, Roland Badeau and Gaël Richard | |
| 33 | Non-stationary t-distribution Prior for Image Source Separation from Blurred Observations |
| Koray Kayabol and Ercan Engin Kuruoglu | |
| 62 | Automatic Rank Determination in Projective Nonnegative Matrix Factorization |
| Zhirong Yang, Zhanxing Zhu and Erkki Oja | |
| 66 | Non-negative independent Component Analysis algorithm based on 2D Givens rotations and a Newton optimization |
| Wendyam Serge Boris Ouedraogo, Antoine Souloumiac and Christian Jutten | |
| 78 | A new geometrical BSS approach for non negative sources |
| Cosmin Lazar, Danielle Nuzillard and Ann Nowé | |
| 85 | Dependent Component Analysis for Cosmology: a Case Study |
Tensors/joint diagonalization | |
| 32 | A time-frequency technique for blind separation and localization of pure delayed sources |
| Dimitri Nion, Bart Vandewoestyne, Siegfried Vanaverbeke, Koen Van Den Abeele, Herbe De Gersem and Lieven DeLathauwer | |
| 43 | Joint Eigenvalue Decomposition using Polar Matrix Factorization |
| Xavier Luciani and Laurent Albera | |
| 116 | Joint SVD and Its Application to Factorization Method |
| Gen Hori |
